Drag Racing Tech
help with DA ASAP
Old Oct 25, 2007 | 08:55 PM
bad6as's Avatar
Default help with DA ASAP
zip code 21713
im using the da calc in the sticky
altidude is 1450
air temp 56.3
Altimeter Setting am i using the right number? this is what i was using Pressure: 18.79 in / 636.2 hPa (Rising)
dew piont 53
im geting a +16779ft am i using it correct?
Old Oct 25, 2007 | 09:11 PM
camscam02's Avatar
that's wierd! i believe the altimeter number is incorrect!?!?!
Old Oct 25, 2007 | 09:13 PM
bad6as's Avatar
what number do i use then?
Old Oct 25, 2007 | 09:16 PM
bad6as's Avatar
but if you do it for 21714 its a -156
Old Oct 25, 2007 | 11:51 PM
camscam02's Avatar
u have the right factor being the altimeter setting, i just think the reading for that areas altimeter is reading wrong!
Old Oct 26, 2007 | 07:47 AM
WS6TransAm01's Avatar
CARTEK Racing
a reading of 18.79"Hg would mean that you are roughly 11,000 feet above sea level. Sea level pressure is 29.92"Hg
Maryland is definably NOT 11,000' MSL
You would pass out in 30 to 45 min at that altitude. Pilots in non pressurized aircraft are advised to have supplemental O2 if they intend to be at that altitude for longer than 30min. That ALT. reading is WAY off
