Drag Racing Tech
mounting front strange shocks
Old Oct 28, 2007 | 07:59 PM
quickta's Avatar
Default mounting front strange shocks
does this look right on how to mount a front shocks with the top bushing
Attached Thumbnails mounting front strange shocks-s2400001.jpg   mounting front strange shocks-s2400002.jpg
Old Oct 28, 2007 | 08:06 PM
chrismorales75's Avatar
Photo is kind of small, make sure the bushing is on the shaft for the bump stop on the shock. then you put the spring in and attach the top then mount the factory bracket over the top of that, I have HAL's but I am pretty sure it is the same thing.
Old Oct 28, 2007 | 08:18 PM
quickta's Avatar
Default shock picture
here is a closer picture
Old Oct 28, 2007 | 09:18 PM
Looks good to me.
Make sure the bushing is in over the shaft for the bump stop so the shock doesn't bottom out.
Old Oct 28, 2007 | 09:22 PM
quickta's Avatar
Default shock
i looked again and the shock came with a bump stop already installed
Old Oct 28, 2007 | 09:23 PM
Looks good to me is it a drag race shock or just a regular single adjustable?
Also what is the front spring rate?
Old Oct 29, 2007 | 06:54 AM
quickta's Avatar
Default shock
it is 300, i was going to go with 275 but the guys at bmr said if you drive around with 275 it may bottom out, single adjustable drag shock
Old Oct 29, 2007 | 11:02 AM
quickta's Avatar
Default shock
any pictures
Old Oct 29, 2007 | 06:06 PM
quickta's Avatar
Default shock
went ahead and mounted the shock and now the holes do not line up at the bottom, mounting holes are wider then the stock ones, any one run into this problem
Old Oct 29, 2007 | 08:20 PM
formula98ws6's Avatar
Yes I had to slot the holes in the bottom of the shock about an 1/8 inch in both holes. I used a die grinder and dressed a mounted grinding wheel down to just fit in the hole. It sucked but didn't have time to send back or anything. I read on here a while ago someone with the same problem before I got mine. All has worked out fine. Shocks work great. !!!!!!!!!!!Good luck!!!!!!!!!
Old Oct 29, 2007 | 08:25 PM
SScam68's Avatar
I had the same problem, but I have the QA1 springs sitting in the cup like the stockers.
Old Oct 29, 2007 | 08:50 PM
quickta's Avatar
did you have to mount the upper shock mount the same way i have it in the first pictures
Old Oct 29, 2007 | 10:21 PM
when you race it you set it to the softer side, driving around with the shocks on #4 or #5 and you shouldn't have problem bottoming out.
Old Oct 30, 2007 | 07:20 AM
kp's Avatar
kp
I use the strange shocks and when I was using the regular coil over springs I had them installed like you do in your pics. I eventually switched from 275s to 300s and just bought the QA1 'generation F' springs that fit like stock on top and are coil over diameter on the shock side.
I originally had 275lb springs on mine (around 3400lb raceweight) and even with the shocks at '10' it was a wallowing mess, especially trying to stop at 150mph so I went with 300s and it really helped with the bottoming out and adjusting the shocks actually does something now at the track.
Old Oct 30, 2007 | 10:24 AM
quickta's Avatar
Default shocks
what settings do you run at the track for the front and rear shocks, so i can have any idea of where to start
Old Oct 30, 2007 | 11:45 AM
kp's Avatar
kp
Anywhere from 3 to 6 on the fronts and the rears I just use the cheapo CE 3 way drag shocks set at 40/60 (or whatever the middle setting is). Good enough for 1.25-1.30 60 foots on my car.
Old Oct 30, 2007 | 07:15 PM
Mine has 300 lbs springs that go in the cup like the orig. The springs came from strange with the shocks they are single adj drag shocks from speed inc.
Old Dec 13, 2007 | 01:33 AM
bigsticksupra's Avatar
how do these drive on the street? can the car speed through corners anymore or are they too soft?
