Drag Racing Tech
First trip to the track tomorrow launch ?
Old Nov 2, 2007 | 08:46 AM
1FSTLS1's Avatar
Default First trip to the track tomorrow launch ?
Going to Mason Dixon in MD tomorrow WITH my car for the first time. Hoping to be in the 11s. M6 with stock size street tires what tire pressure and how many RPM lo leave at. ANy other tips I am totaly pumped!
Old Nov 2, 2007 | 10:28 AM
TeEnAgE pHeNoM's Avatar
I don't know your suspenision mods but if they are drag radials I would run 18-20 psi of air and launch at 4000 and try to get a good clutch slip.
Old Nov 2, 2007 | 11:07 AM
1FSTLS1's Avatar
stock suspension and stock tire street radial
Old Nov 2, 2007 | 11:39 AM
98TADRIVER's Avatar
on street tires?? heh good luck with shooting for 11s. a buddy of mine runs 10.9 @ 127 with his cam only t/a with full suspension and dr's. on street tires i think he hit mid-high 11s @ 118-120 and he can drive quite well. (1.49-1.59 60's on the DR's) plus its your first time running it? I'll say low 12s @ 118 mph. not putting you down or anything. hell i could be completely wrong about your times! lol let us know how u make out. when i was on street tires, full weight with a few suspension mods, i was leaving the line between 3800-4500 rpm slipping the clutch quickly and managed a 1.89 60' on street tires. then after the next couple runs, my 10 bolt died lol
Old Nov 2, 2007 | 11:43 AM
Ericbigmac83's Avatar
Good luck, but it sounds like youre gonna pretty much need to leave off idle to avoid spinning. Practice launching on the street before you head over there, i wouldnt launch over 2k rpms though, but 1500 is prolly about all you'll be able to launch at
Old Nov 2, 2007 | 12:08 PM
1FSTLS1's Avatar
Yes the street tires suck and I realize my times may suck. Maybe I should practice frying the tires and launching tonight and make my street tires into slicks!
Old Nov 2, 2007 | 12:20 PM
chrismorales75's Avatar
Do not do big burn outs on street tires and do not lower the psi.
Drive around the water box and just spin the tires to clean the rocks off.
If you lower the psi or try to do big burn outs on a stock tire it will lose traction potential.
Leave around 2500 and try to keep it from spinning, don't just drop the clutch, try to keep the rpm up and let it out as fast as you can without spinning or bogging and I wouldn't use the n20 till 2nd gear.
Most likely you try to leave at any rpm and hit a shot on a street tire right from the start it'll just spin.
Go do a burn out, spin the tires and roll forward and get out and look at the rubber on the ground it should be even black across the burn out, if the outside is lighter take out a couple psi, if it is lighter in the middle add some air.
Old Nov 2, 2007 | 01:29 PM
Lol, i wish that worked, i would have plenty of slicks lying around in that case. its all about tire compound unfortunately
Old Nov 2, 2007 | 01:58 PM
streSS's Avatar
we have really similar set ups when i had 370 to the wheels on street tires i would lower the psi to about 26 and leave at 1800 rpms my best times were 12.7 at 112 with 2.1 60's. I went 2 days ago after installing a ls6 and p/p throttle body and smooth bellow the best time i could run on my street tires was 12.9 with 2.2 60's at 115mph so good luck figuring it out on the track
Old Nov 2, 2007 | 03:31 PM
1FSTLS1's Avatar
Just tried a few passes in the street. I just fry the tires tried at 18 2k 3k Oh well Ill still have fun and see what happens.
Old Nov 3, 2007 | 01:27 PM
1FSTLS1's Avatar
13.45@116 first run got off good in first then hit 2nd and just fryed the tires off then hit the juce in 3rd.
2n run 12.97@114 got first and 2nd to hook fried 3rd had to back off. Not bad for firs time.
60fts 2.4 and 2.1
