help with drag suspension shocks and ta length
i know ill proll need a 300 spring!
ta, long or short? i beleive short hitts harder so i might need it to help get off the line right?
my car is a lt1 385 with a 76mm frount mount, proll lookin in the 600-700 power range, the car is a m6 and has some weight off the front, no bumper support, no ps, no ac, tube k. i think my 330 will determine how it runs!
The AFCOs are one of the best out there, but you can get by with the single adjustable stuff. If you get a single adjustable, make sure you get ones that have fixed, firm compression & adjustable extension so you don't come down hard on the launches.
If money is a concern, each selection gets cheaper as you go down.
Strange double adjustable front, single adjustable rear.
Strange or Qa1 single adjustable front "r" shock, fixed compression, single adjustable rear.
The cheapest way, strange or qa1 "r" fixed compression front and C/E 3 way adjustable rear.
