Drag Racing Tech
need an easy tenth
Old Nov 6, 2007 | 08:06 AM
omcar's Avatar
Default need an easy tenth
car is a '01 formula A4 w/3,600 vig/ 3.73s/ pulley-lid-smooth bellows-gmafs. Car has all the good susp stuff and tires (1.57 60'). I'm running 12.03- 12.10 and want 11.99. I do take everything out of the trunk and run at 1/4 tank. Thanks
Old Nov 6, 2007 | 08:22 AM
jason02Z's Avatar
wait for perfect weather conditions. and if u get 1 thenth off the sixty that adds up to about 2 tenths in the 1/4. check out the weight reduction list at the top. see what u dont want in ur car for free mods
Old Nov 6, 2007 | 08:28 AM
98LS-WON's Avatar
Take the seats out before you go to the track. That should buy you a tenth if you don't mind the work. You can relocate the battery to the trunk to help the 60' too.
Old Nov 6, 2007 | 08:54 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hmm, how about liteweight battery and !jack/spare, and !front swaybar.
Old Nov 6, 2007 | 09:00 AM
02SS:ZEUS's Avatar
Every 100 lbs is about .1 off you 1/4. It's gonna take more than your back seats. lol I would just wait for some cooler air temps, or depending on where you are, take a road trip to a lower altitude track.
Old Nov 6, 2007 | 09:04 AM
jason02Z's Avatar
also go get it weighed so u can have a good idea where to start ripping **** out
Old Nov 6, 2007 | 11:23 AM
omcar's Avatar
Thanks guys...I'll keep at it.
Old Nov 6, 2007 | 08:19 PM
James Montigny's Avatar
Temp makes a huge difference
Hit the track early some chilly morning at a test/tune event
I managed to drop from 12.0 to 11.8 that way last week
Near-0 DAs kick ***.
Old Nov 6, 2007 | 08:22 PM
Krazy98Z28's Avatar
Take your airfilter out and run a shortbelt
Old Nov 6, 2007 | 08:26 PM
95 Z28's Avatar
yup...yank some worthless weight out too if you haven't already like the spare/jack, all seats except drivers, front sway...I'd bet that coupled with some favorable weather will get you those 11.90s
Old Nov 6, 2007 | 08:57 PM
chrismorales75's Avatar
bypass the power steering, that alone will give you more than .1
Old Nov 6, 2007 | 10:57 PM
CamaroRacing12's Avatar
every little bit helps... remove as much weight that u find fitting... go on a good air day... and drive the hell out of the car... plus a damn good burnout
Old Nov 6, 2007 | 11:53 PM
Maybe a better driver can get you a .1 =)
