Drag Racing Tech
Lowering A Drag Car
Old Nov 6, 2007 | 09:05 PM
XpEdItIoUs's Avatar
Default Lowering A Drag Car
What springs can I use to lower my car and not affect performance? After I went with a 9" and weight reduction my car sits alot higher.
Old Nov 6, 2007 | 09:36 PM
fash00's Avatar
the wolfe adj spring perch kit
Old Nov 6, 2007 | 09:43 PM
FiredUpZ28's Avatar
^agreed^
Lowering springs don't allow weight transfer as well as factory or drag specific springs, which can actually hurt your 60' .
Old Nov 6, 2007 | 10:47 PM
chrismorales75's Avatar
10" coil over spring in back with adjustable perch
Old Nov 7, 2007 | 12:25 PM
xpndbl3's Avatar
remove the rear rubber isolator and just put heater hose around the top coil of the spring and it'll settle down the 2" or so in the rear, I had to do that on my camaro as well since it sat like a 4x4.
Old Nov 7, 2007 | 12:40 PM
Matt D's Avatar
Retired Street Racer
Or you can cut the stock springs. That works too and is free.
Old Nov 7, 2007 | 06:20 PM
FASTFATBOY's Avatar
Be careful about lowering the car with a 9 inch, it may hit the fuel tank. Especially if you have a fluid fill in the top of the rear.
I have a set of Global West rear springs with adjustable perches, They fit in the stock location $150.
David
Old Nov 7, 2007 | 09:03 PM
XpEdItIoUs's Avatar
Done that, I have qa1's on the front but the rears is the problem.
Old Nov 8, 2007 | 03:32 PM
TS6's Avatar
TS6
Thats what I did. Works well.
Old Nov 8, 2007 | 04:03 PM
1BADAIR's Avatar
stock rears cut here
Old Nov 8, 2007 | 06:21 PM
GueSS Who's Avatar
Not only does it hit the gas tank it will also hit the rear most part of the tunnel. I had to cut my tank and notch my tunnel but my **** is slammed on the ground though.
Old Nov 8, 2007 | 06:54 PM
FASTFATBOY's Avatar
Mine did that also, I have also notched the tank. I have a Spohn Tq Arm in the car. I removed it and cut the inside holes of the mounting bracket off centering the arm in the tunnel. Which is what the instructions said to do...I just didnt read them until after I "clearanced" the floorboard.
David
Old Jun 17, 2009 | 08:40 AM
98Camarod's Avatar
They sell two. Which one did you get and do you have any pics of it mounted? Did you remove the isolator?
Old Jun 17, 2009 | 11:02 AM
03 BUSA's Avatar
I was told by many sponsors that the f-body likes a stiffer spring in the rear so I kept my hypercoil lowering springs in the rear. If they do not work when I go to the track I will swap to the stockers with the heater hose mod.
Old Jun 17, 2009 | 02:32 PM
Lone Warrior's Avatar
here is Wolfe under my 94 Formula
Old Jun 17, 2009 | 04:32 PM
a98ws6's Avatar
I didn't know a 9" will raise the car? Why is that? I took out my isolator and have rubber hose on my BMR 1" lowering springs and I just bought a Moser 9". I don't want it sitting high. I'm not looking for a low rider here but I like the tire tucked a bit.
Old Jun 17, 2009 | 05:11 PM
1BADAIR's Avatar
because the axle tubes are bigger which in turn makes the spring pads higher
Old Jun 17, 2009 | 06:56 PM
383lt1impala's Avatar
Do u have the motor and trans back in it? If not wait.
Old Jun 17, 2009 | 06:59 PM
6techniques's Avatar
subscribing. good info to know in here.
Old Jun 17, 2009 | 07:14 PM
MattysTA's Avatar
i have 1" lowering springs in the back and for now stock in the front. cut the 60ft in my sig with that setup. only other suspension is boxed trailing arms..
