adjustable shocks or k-member
I need help gettin my 60' down best of a 1.8 that was with a slippin clutch, it has a new on in now.
my suspension is as follows
bmr adj lca
bmr adj torque arm
bmr relocation brackets
qa1 single adj rear shocks
26x10 slicks
what will help me get my 60' down more adj front shocks or a bmr k-member
You want something that is double adj -in the front especially, so you can control both rebound and compression which is crucial for a proper launch. I realize it is a gift, and that DA shocks are $$$, but trust those who have done it wrong the first time. Get DA shocks and never look back!!!!
AFCO DA's are $$$$ but very nice (what I have). Look into HAL QA1 DA shocks. Worth the dough. There are other brands too but they are even more than AFCOs. PM me if you have any questions or want to order, we can help.
Good luck
Erik
E
Unless you are going for MAX EFFORT with your setup, the singles will work just fine and save you money for other things.
If you have the $$ the DA shocks are a no brainer, if you dont have the cash then I would take a set of SA shock over the stockers any day. Are SA's the bestest most awesomest shocks in the world? No, but plenty of people run fast with QA1 Rs ot Strange SA shocks.
(2) SA Strange Drag shocks from SJM manufacturing $146 each
(2) Torrington bearings- Some people use never sieze instead, when you start adjusting the ride height without these it will be a horrible pain in the ***. I believe these were $20 or so from Steve @ SJM
(1) GOOD spanner wrench( not a cheap piece of ****, once you start installing you will thank me) I bought one from a speed shop local, it was a piece of crap...luckily a friend had a good one
(1) Pair of BMR spring cups to use stock springs $60, I used these rather then buy new springs.
