Drag Racing Tech
Braided fuel lines
Old Nov 25, 2007 | 03:32 PM
842ta's Avatar
Default Braided fuel lines
On my carb set-up I have rubber fuel lines and I want to run the black braided nylon. I have never ran and lines just wondering what size I needs to runs and if any certain brand is better than another?
I was thinking of something like this
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 25, 2007 | 06:53 PM
99.9percenter's Avatar
You most likely will need a line bigger than -6an. -6an is only about 5/16 inch Id.
Old Nov 25, 2007 | 07:48 PM
01bad ss's Avatar
You will need -8an or -10an sized.Dont know your exact set up or power output but that is the norm until you make a lot of power.I run -10an from tank and pump to the regulator then -8an from the reg.to the carb,then run -10an return back to the tank.My lines are braided steel lines,all fittings and lines are very costly but look sweet.
Old Nov 26, 2007 | 10:39 AM
mrdragster1970's Avatar
6 & 8 Second Club
The way we do all ours, might be overkill in the beginning, but will last forever.
tank to filter/pump AN-12,
pump to Y-block AN-10,
Y-block to carb regulator AN-8,
Y-block to N2O regulator AN-6,
regulator to carbs AN-6 each bowl
If using a log or single inlet, AN-8
return line from pump to tank AN-8
air return from regulators to tank AN-6
Old Nov 26, 2007 | 10:44 AM
T Pizzle's Avatar
I would def. run -8 or even -10.
Old Nov 26, 2007 | 12:10 PM
chrismorales75's Avatar
For a street car with a street type pump I would go -8 from the tank to pump, pump to regulator, -6 from regulator to carb with a -6 return.
For a race car with a big race pump I would use a -12 tank to pump, -10 pump to regulator, -6 regulator to carb with a -8 return line.
As far as lines I think the push lock stuff is pretty affordable, light weight and flexible.
