Drag Racing Tech
How should I get off the line in my automatic?
Old Jun 22, 2003 | 07:19 PM
CamaroSS's Avatar
Default How should I get off the line in my automatic?
I was thinking about going to te track this Friday, and I was currious, how should I get off the line? Should I rev it in neutral then shift to drive? Should I just ease it in on the throttle? Or should I just floor it? I have an automatic 2001 SS with traction control. What sould I do? Any help?
Old Jun 23, 2003 | 02:05 PM
SSteveL's Avatar
Default Re: How should I get off the line in my automatic?
Turn off traction control. Keep tires fully inflated. Do not do a burnout, but a quick spin will shed gravel from the tires.
At the line a good technique is to preload the converter by keeping your foot on the brake and bringing up the rpm a little bit. A good reason to do this is to prolong the life of your transmission (i.e., it lessens the shock of the launch), but don't keep the revs up longer than necessary (you'll heat up the tranny fluid).
At launch, lift from the brake as quickly as possible and gradually bring the throttle to the floor (say, over the first second or two; you'll have to feel out the launch). Unless the track is very well prepped, your tires will spin if you floor it, and you'll waste the run.
Old Jun 23, 2003 | 03:11 PM
badass 2002 z28's Avatar
You DO NOT, I repeat DO NOT want to neutral drop it! Do as SSteveL said
Old Jun 23, 2003 | 10:11 PM
beardWS6's Avatar
What they said. Leave it in drive!
