Drag Racing Tech
do I need something else ? For Drag setup
Old Nov 27, 2007 | 06:08 AM
camaro_best's Avatar
Exclamation do I need something else ? For Drag setup
hello every one
the car now camOnly camaro 1998 A4
- lid - catback - lt's - ls6 intake
- 3.42
- Tc 3500 2.5STR
- weld prostar 15 X 8 rear with 275 / 60 / 15 Dr's
weld prostar 15X3.5 front
- VFN hood
- 400Rwhp 383Rwtq
- not DD car for race only
time for some shocks and springs ??
-Front shocks - Qa1 "R" with 275lb
-Rear Shocks Comp Engineering with stock springs 3 way adjustable 40/60 50/50 70/30 ratios which way for me ? 50/50 ?
-what do you think guys do i need something else ? for install ?
- what another parts to improve the 60'ft ?
Old Nov 27, 2007 | 07:37 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
adjustable shocks on all 4 corners, tunnel mounted torque arm, adjustable lca's and rearend relocators. this combo is proven to go 1.4x 60's with a4/footbrake/3.23's.
Strange s/a shocks/springs, chromemoly double adj t/a and lca's. all parts powdercoated. 1450.00 shipped
Old Nov 27, 2007 | 08:20 AM
thanks for replay
now only shocks and springs after save some $$ i'll get the other parts.
any other suggestios ?
Old Nov 27, 2007 | 03:28 PM
Out1aw's Avatar
9" or Dana 60 rear with a tall gear should be a big consideration.
As far as suspension, if you want a stock-style setup:
Adjustable tunnel-mounted Torque Arm
Adjustable shocks all the way around with 275-300lb spring up front
LCAs with relocation brackets
Adjustable Panhard Bar
!Front sway bar
Rear drag bar and subframe connectors later when actually needed
Old Nov 27, 2007 | 04:30 PM
Steve Burger's Avatar
LS1TECH Sponsor
I would do the subframe connectors first. They take a lot of flex out of the chassis,
