Drag Racing Tech
Spring Seat Adjustors or Shocks?
Old Dec 17, 2007 | 07:04 PM
MetallicaMatt's Avatar
Default Spring Seat Adjustors or Shocks?
Hey guys,
I've been getting a lot of advice from a bunch of different people about getting my car ready to see the 10's
I have one person telling me to buy the Wolfe spring seat adjustors to run with my QA1's
I have another person saying that I might not really need the adjustors, and I can just adjust my QA1's depending on track conditions
remember 6 speed car, hard launches (5000+ RPM dumps) and 150 shot
Do I need adjustors? Or just roll with the QA1's?
Old Dec 17, 2007 | 07:10 PM
RAGENZ28's Avatar
What is your purpose for the adjusters? To change ride hight?
If your car is at the hight you want now I don't see any reason to get them.
Old Dec 17, 2007 | 07:56 PM
JL ws-6's Avatar
Race your car!
3 weeks ago I ran 9.61 with stock springs in the rear, just the isolaters reoved and a piece of rubber hose over the spring to stop the metal to metal.... If you have qa1 shocks on there you are fine you don't need coil overs or the adjustable spring perches.
for a referance, I was running mid 10's all season n/a, and my suspension consiss of:
qa1 12 way rears set at 5
wolfe drag bar preloaded about a 1/4 turn to get the car to leave level
relocation brackets one hole down from stock
adj panhard and lca's squaring the car up
bmr chromoly stock style adj. tq arm, -2 deg pinion angle
bmr th400 crossmember with tq arm relocation, tq arm 4 holes up from bottom with the lower bolts
qa1 R series front shocks, set on 4
275 lb springs, adjusted so the front ride height is about an inch lower then stock
Nothing special or fancy, and it works pretty good. Car consistantly will 60 foot 1.4x's on motor off the transbrake and ran a best of 1.35 on a little 100 shot of nitrous, went faster with the 150 shot but it actually 60 footed worse. 3500 lb race weight too, so it's far from light.
Old Dec 17, 2007 | 08:03 PM
RAGENZ28's Avatar
I have my springs adjusted 1" up with 10" coilover springs, and I will probably lower my car 1" after I put on the taller tire, which won't even leave me any room to go below that
The other thing is once it's that low the stock length shock is almost bottomed out. I only have about 2" of travel left downward now.
Old Dec 18, 2007 | 04:29 AM
JL ws-6's Avatar
Race your car!
never mind the rear hitting the hell out of the floor and needing to basicially cut out a chunk and remake a piece for clearance, plus like you said with the shorter shocks, and at some point the frame rails are gonna be an issue.
