Drag Racing Tech
Pics Of Wolfe Raceing Upper Rear Spring Mounts
Old Jan 2, 2008 | 04:59 PM
WS6 Canada's Avatar
Default Pics Of Wolfe Raceing Upper Rear Spring Mounts
Does anyone have pics of their Wolfe upper spring mounts? installed?
Also how do you install them, do you just cut down the factory spring hump or remove the whole factoy mount???
I just received them today and would like to get them installed..
thanks
Old Jan 2, 2008 | 06:38 PM
DMH Fabrication's Avatar
There are a bunch of pictures on wolfe's site from what I remember. You may want to check on there.
Old Jan 3, 2008 | 10:24 AM
Z06kern's Avatar
Here is some pics of mine when I was installing them.
Old Jan 3, 2008 | 11:16 AM
MetallicaMatt's Avatar
not to steal your thread, but i was considering these also...but are they worth all of the hassle of cutting up the car?
I'm just not sure if I would need those??
Old Jan 3, 2008 | 11:50 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
They're a big help for tire clearance...especially if you've mini-tubbed your car.
Old Jan 3, 2008 | 05:26 PM
WS6 Canada's Avatar
How did you cut out the sheet metal??? Grinder?????
Old Jan 3, 2008 | 05:31 PM
Other than getting tires to fit (i'm going to run a 28"x10" --should be no problem)
why would someone need these?
cutting wheel would easily cut the sheet metal
Old Jan 4, 2008 | 08:00 AM
Z06kern's Avatar
Plasma Cutter
