Cage install prices?? (I know, again)
Look around and ask around that's all you can do, you pay for what you get, but you're not getting a cage built, fit, prepped, you're paying for straight welding so don't be a sucker.
*** EDIT ***
OK so I found my estimate and took a screenshot (taking out the companies name), so here it is...
http://www.1slowformula.com/images/cage_estimate.jpg
That Looks like my invoice.. So are you ready for a cage yet.. Let me know..The pricing has changed some since that estimate has been done do to inflation of 08
~Tyson
Yeah it is your quote Tyson, but I figured the price has changed since it has been almost 10 months since I asked for it, that's why I tried to blur out the shop name in the image... I wish I was ready for it, I have all the mods I need in my basement to get me deep enough to need the cage, but I am trying to get this damn bolt-on record first, and it has been a little tougher then I thought. I would hate to have to step up the gear just for the record then need another gear change when I do my next round of mods...
I should definitly need it this year because I don't think I will be happy staying at 12.0 for too long, everyone else in the series I race in is getting faster and I would hate just sitting still...
The halo will be a pain to weld completely around if it's all tacked up and the main hoop is already welded to the plates and rocker bars.
You need to be able to have some movement inside the car to get it completely done.
Then you're only talking a few hours to finish weld it.
Even at 100 an hour to weld (not sure of the going rate) it'll be a 200-300 labor charge
Then you can send me the extra for beer money and we can celebrate the extra green backs in your pocket
It was a 10 point. Considering there is 20 welds regardless of what anyone says I wouldn't pay 1,000 plus just for the welding, if no one else has someone to help them out getting a better deal I don't know what to say, just that I wouldn't and dont have to pay that much personally.
It's not unreasonable nor impossible, I've personally seen it done and helped do it.
4x rocker bars
4x door bars
2x dash bar
2x main hoop
2x main hood cross bar
2x halo
4x front cage bars
4x rear bars
4x Tunnel bars
8x Plates
36 welds off the top of my head for a regulation cage in an f-body
that doesn't include any extra bars
If you have weld in sub frame connectors you may not be able to holesaw the floor to drop the cage through even if you do howl saw and the rocker bars are in it won't lower it much.
Any tube not welded 100% around would require a gusset.
it will take a more than 9 min a weld specially when you get up around the head liner.
Plus if you're running through the floor subframes you'll only use 2 plates in the rear behind the seat. Everything else gets welded to the subframes and outriggers.
Some bars might take more than 9 minutes to weld, but a lot of welds are much easier to get to and won't take more than a couple minutes to weld.
If you subtract those two bars one for the door and one rocker thats still 32 Welds that have to be done.
