Before I go to Summit...
I'm going to buy 15x 3.5 and 15x 10 Bogarts in the spring, so these are the tires I was going to put on there...let me know if it looks right
ET Street, LT 28 x 11.5-15, Bias-Ply, Blackwall
ET Front Drag, 26 x 4.5-15, Bias-Ply, Tubeless, Outlined White Letters on Both Sides
Are the ET Front Drag tires street legal? I didn't see any tread on them lol
I don't know how big of a tire you can fit or want to fit, but the ET Street tire doesn't measure like a slick, slicks are hight x tread width, ET Street are hight x section width.
If you can fit it I would think about the 28x12.5 ET street it has a 10" tread which will be a little better hooking on the street.
The 28x11.5 ET STreets tread is only like a hair over 8.5" if I remember right.
I have a 15x8 right now, that's why I am going with the 29x11.5 Hoosier QTP DOT, it has a 10" tread. Until I get my 15x12"s then I'll run the 30x13.5.
A bigger tire will most likely slow you down at the track, but if you're street racing or mostly want better street performance, the bigger tire will work better on the street.
I need something that will hook....so are ET Streets not the ticket?
I need something "street legal" though, running those Bogarts?
I bought a fender roller, and figured i would also have to do the BFH method to the inner fender
So what should I do?
I would look at the ET STREET 28x12.5 or Hoosier QTP DOT 28x11.5
Both have a 10" tread and should fit. Main thing will be getting the right offset rim, 1/4" one way or another can make a huge difference.
will the 12.5" fit? how much will I need to work on the car to get them to fit, i don't want to tear it up
so will these tires fit? I see your running 11.5"
Not that I don't trust you, its just your the first to suggest a wider tire.
Is your rear end stock width?
For the track, they are my first and only choice, and SJM's service is top notch.
For the track, if your car is under 3400 lbs I'd run the et front size you have listed and a 28x10.5S, part # 3055S from m/t on the rear. They are a great tire and will hook with yoru plans, but if you have a heavier car then run the 4 ply sportsman fronts, because that et front tire will roll right over if the car ever gets out of shape and is too heavy, seriously not safe. If you are planning on street driving the car the sportsman front is a must. The et street will work on the street, but like mentioned above they do measure a little different, and at the track they won't work as good IMO as a et drag does, at least that's what I've found from my own personal experience.
my car is a hog, she's full weight and then some probably, so I'll run the Sportmans upfront
so is the 10.5 wide enough meat? probably ~550rwhp off the line, thats it for awhile
I was going to get the ET Streets from Summit Saturday morning, so let me know
Thanks guys!
I would love to run the 12.5" but I am doubting they will fit
I've personally have seen quiet a few 8 sec passes on a 28x10.5
I don't think you under stood what I said about the ET STREETS, a 28x12.5 ET STREET is the about same size as a 28x10.5 slick.
If it is a drag only tire run a true slick, if you're gonna street drive it I would get the ET Street or Hoosier QTP DOT.
Like JL said the 28x10.5S is a good tire S means stiff sidewall which works good on stick cars.
Thanks guys!
Sorry guys, I got all confused, I was tired. I'm glad to see the ET Streets will work just fine.
Does anybody know the Summit Part Number for the 28x10.5S?
I would have figured I would need a softer sidewall.
Thanks guys!!
