tire size vs. gear
thanks,
Brandon
I would run a 255/50/15 DR's with the 3.73 gears,that will net you a better over all ET with your gear and converter. I used to have that converter years ago and it works really well. My buddy has it now and has ran several 1.59 60fts. NA and a few high 1.4 60fts. on the bottle with the tire i stated above with a 3.23-3.73 gears.
Sell those 28" and get the 26" tall tire or you will regret having them.
so going from a 26" tire with 3.23's to a 28" tall tire with 3.73's would be the gearing equivalent of just switching to 3.42 gears. not really a change that is worth anything.
if you are looking to optimize your gears for track performance you kind of have to start at the finish line and work your way backwards. you want your gearing and tire size to work together to produce a trap RPM that is a bit past the peak power rpm as you cross the line. so if you make peak power at 6k rpm you want to cross the line at 6200-6400 rpm to make sure you use every last drop of power as you go down the lane.
I'm spraying 150 off the transbrake on 28" slicks, went 1.38.
You could do it with a shorter tire but the taller tire sure helps when you start adding more power to it, especially leaving with nitrous right off the go.
Bigger tires will slow you down, but having a little more tire really helps keep it consistent and when the track you run at isn't it's best it really helps.
On a car with a marginal chassis set up or adjustability the bigger tire can really help the 60ft.
To be honest what I would do first is change the gear and keep the SAME tire for now. You can still trap 135 at 6500rpm with a 26" tall tire and 3.73 gear, so that should be more than enough for your N2O mph. If you still have a 10 bolt the lower your gear the more likely they are to break. A 3.23 will be stronger just due to size...
Here is a good website you can play with gear ratios and tire sizes all day long....
http://www.f-body.org/gears/
Chris
Chris
With a 26" tire and a 1:1 tranny ratio here is your mph vs rpm:
Speed (RPM)...Speed (MPH)
8000 RPM 191.58 MPH
7500 RPM 179.61 MPH
7000 RPM 167.63 MPH
6500 RPM 155.66 MPH
6000 RPM 143.68 MPH
5500 RPM 131.71 MPH
5000 RPM 119.74 MPH
4500 RPM 107.76 MPH
And here is 3.73's with a 28" tire:
Speed (RPM)..Speed (MPH)
8000 RPM 178.66 MPH
7500 RPM 167.49 MPH
7000 RPM 156.33 MPH
6500 RPM 145.16 MPH
6000 RPM 133.99 MPH
5500 RPM 122.83 MPH
5000 RPM 111.66 MPH
4500 RPM 100.50 MPH
So by going with 3.73's and 28" tires you will numerically increase your overal gear ratio and it should increase acceleration and decrease top end. -Mark
