Guys running rears narrowed 3" on each side
My car is mini tubbed with offset lca's. My question is what backspace can I run to completely tuck a 315/60 15?
Go to
www.teamprickracing.com
and look around
David
David
The 5.5 would be perfect with the 3inches off each side
Probably not gonna hit the lower control arm, the bolt through the lower control arm relocation bracket is the problem. You need to make the BRACKET on the rear end itself 1/2 it's original width and use smaller or no spacers.
The control arm stays as far to the inside as it can. In the front hookup point on the body.
David
David
ls1408 that is a nice tuck. I already have the rear narrowed 3 and in the car though.
Thanks for all the responses!!
