Drag Racing Tech
HELP a.s.a.p.
Old Feb 5, 2008 | 07:06 PM
silver 2000 ss's Avatar
Default HELP a.s.a.p.
wanted to know if a 28x10.5 M/T would fit with the budget summit rims 15x8?
I got a 2000 camaro with stock ride hight.
Old Feb 5, 2008 | 07:48 PM
Matt D's Avatar
Retired Street Racer
Yes, that will fit. I had the same setup on my '00 Camaro. You will just have to trim your fenders a bit to compensate for the tire growth on the big end.
Old Feb 5, 2008 | 08:56 PM
1STGEN68-2000SS's Avatar
Before you go down the track do a long burnout and check your tires for any signs of rubbing. If you trim the bumper panel be sure to bend the metal plate at the back of the fender opening or it WILL cut the tire.
Alan
Old Feb 5, 2008 | 09:07 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
no problem on the tires and rims working together, as I know plenty of people running a 15 x 8 rim with a 28 x 10.5 tire. They rec. a 10" rim but it will work.
Clearnace issues are another story altogether......
Old Feb 6, 2008 | 04:16 AM
Thanks guys I dont mind beating up the inside of the fender well too much. I got a couple of track rentals soon so I need to order some parts fast.
