just a few chassis questions
first, does anyone know the rate of the stock 6 cyl front springs on a 93 camaro? what im getting at is I am building a bracket car and need to know if i should buy after market front springs or if the 6 cyl. springs will transfer weight with an aluminum headed sbc. I know in the old days it was common place to put 6cyl springs in your big block car to get better transfer.
also, the car has a ten point cage that just got certified yesterday and i was wandering at 10.50s with stock suspension do you thank the ten point stiffens it up enough or should i put sfc,s in it also.
thanks in advance for the help guys
DAVID
