Drag Racing Tech
taller tire??
Old Mar 11, 2008 | 04:32 PM
BlackSS2001's Avatar
Default taller tire??
Ok I'm just thinking here but I'm running out of 4th gear before I hit the 1/4 mile. My 60's are really bad so far due to lack of funds for DRs (2.53). I'm hitting 117 in the 1/4. but I'm letting off because I hit my rev limiter. and if I shift into 5th my rpms drop to much.
Any ideas/thoughts?
I think droping my 60' will help with this problem also..
Old Mar 11, 2008 | 07:34 PM
N2RACINGLS1's's Avatar
What do you have the rev limiter set at?
Old Mar 11, 2008 | 07:52 PM
Ok I saw where all of this has already been discussed in another thread you started. Change your rev limiter to 6,800 RPM and shift at 6,600 RPM and you tire combo should carry you through the 1/4 mile. With the mods you have that is about the lowest you should be shifting at which has already been stated before.
The higher you shift the further down the track the car is!
