Hey A4 Guys...
2.73 gears. No stall yet.
STB, LCA, PHR, TQ ARM, SFC, Stock springs, Stock Struts.
I launch at 1000 RPM
Nitto Drag Radials 275/40/17's at 25 psi.
13.6 @ 103 mph. with a 2.0 sixty foot.
What would I change about my setup??? Alot.
28X8.5 M&H race master ET street type tire, no power brakes, no trans brake, skinnies.
Have a slip from the previous owner that has a 1.6 60 foot time. Would noot hook on the bottle and I think hazed them on the motor.
Car now has same size tire but its a MT ET street, lighter wheels, double adjustable LCA's with rod ends, QA1 adjustable drag shocks out back, has LCA brackets waitning to go in.
On the street I can get the car spun up to about 2300-2500RPM and the car hooks on street air pressure and cold tires.
Next I am going with AFCO coil overs all around, adjustable TQ arm, weld in rear drag sway bar, Neil Chance stall, trans brake all after more motor work and speay like a 300 shot out of the hole.
My last car pulled like a 2.1 out of the hole (ran a 13.81 that run) and this car would spank that car out of th ehole on the motor.
Going to do some 60 foot runs when it warms up on the motor. I am hoping for close to a 1.6 but nothing faster on the motor and foot brake.
HAL QA1 F-Series Rear Shocks (12 pos)
HAL QA1 300lbs Front Springs
Tubular Lower Control Arms
Spohn Adjustable Torque Arm w/ loop
Spohn Pro-Series Rear Drag Sway Bar
BMR weld-in LCA Relocation Brackets (middle hole)
Pirate Motorsports weld-in sub frame connectors
Yank SS4000 Torque Converter
Weld Prostar 15x8; Mickey Thompson ET Street Radials
Launching off the footbrake slightly above idle (to take the slack out of the drivetrain).
1.588 has been my best 60ft so far. Full-weight car
PA Racing chrome moly k-member
PA Racing chrome moly upper & lower a-arms
UMI subframe connectors
UMI chrome moly trans mounted torque arm
Spohn lower control arm relocation brackets
Pavlock aluminum lower control arms
Pavlock aluminum panhard rod
Spohn chrome moly 1" rear sway bar
QA1 "R" front drag shocks w/ 275lb drag springs
Competition Engineering rear drag shocks w/ stock, cut springs
Lakewood driveshaft safety loop
15x4 Centerline Convo Pros w/ 26x4.5x15 Mickey Thompson ET Fronts
15x7.5 Centerline Convo Pros w/ 26x8.5x15 Mickey Thompson ET Drag Slicks
Stage 4 FLT 4l60e transmission
Yank Pro Thruster 4400 stall torque converter
LS2 flexplate
bmr rear drag bar
bmr lca
bmr torque arm
launch at 5500 on the tbrake
5200 stall Ati 8 inch
26x10x15 et drags on prostars
15x26x3.5 mt fronts on convopros(for now)
best 60ft is 1.47 but thats with a dead hook with only 9psi
I am thinking if I add more air I can get that to 1.45 or so (3450 race weight)
BMR chrome moly LCAs
BMR SFCs
BMR chrome moly panhard rod
stock shocks
stock springs
15x4 Bogart D10
15x9.75 Bogart D10
MT ET fronts
MT 275/50/15 ET street radial 18 psi
Circle D 3600, as high as it can go w/o moving on the footbrake
best is a 1.575
