Open Car Trailer, Ramp Help!
I didn't have any dragging problems initially. With a 27 inch rear tire and the front at stock ride height it would load mo problems without hitting at all. When I lowered the front an inch, still no problems, went to a 28 inch rear tire, now the nose is pitched down a little and it will run if I don't use the boards.
I now just have a 4x4 hunk of wood that I put under my trailer tongue jack, and crank the tongue jack up. Works fine. My trailer has a dovetail though, looks like yours doesn't, so you may need the full lift of the Rhino Ramps.
I made some extensions out of some 2X12's. I cut a 2.5' piece for the bottom, 1.5' piece for the middle, and a 6" piece for the top. I just place the current ramps on top of these to lessen the ramp angle. I got the idea from a post on here.
