Drag Racing Tech
It was really hot but...
Old Jul 27, 2003 | 05:55 PM
mikey's Avatar
LS1TECH Sponsor
Default It was really hot but...
Went to an all Pontiac event today at Maple Grove here in PA. The weather was horrible. 94 degrees, 72% RH, 30.02 Baro. Weather guys, what's the DA and elevation at Maple?
I expected the car to run it's normal 10.0 - 10.1's which it normally does at this track and weather conditions. First pass of the trailer the car went a 9.893 @ 135.65! All I did since Bowling Green was went with a new converter from T.C.S. (thanks Derek!) and re-build the broken tranny. The weight is still at 3223 where is was at BG. The new converter is a little tighter down low so my 60's were in the 1.37's (usually 1.33's) but it really pulls hard up top. During the launches, the car did not pull the wheels at all. These passes where foot braking, no t-brake.
There were a whole string of break downs and delays but the second pass yielded a 9.893 (yes exact same ET) @ 135.96.
Before we could get to eliminations, someone hit a utility pole outside of the track and knocked the power out. One delay after another along with the oppressive heat and we decided to pack it in.
Funny thing is that I usually run 0.2 and 2 MPH faster at Cecil on any given day. I can't wait for fall weather.
Hey Wade, you guys build one hell of an engine!
Old Jul 27, 2003 | 05:57 PM
DERTY's Avatar
The Bull
Default Re: It was really hot but...
That's awesome Mikey.
Old Jul 27, 2003 | 06:00 PM
thechef's Avatar
Moderator
cool mikey i been hearing nothing but good things about Derek and TCS
Old Jul 27, 2003 | 06:06 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Cool,Mikey good to see your running strong.Once Wade and crew finish my 422 I will get to go out and have some fun too.In the fall weather you should get a new best.
Old Jul 27, 2003 | 06:10 PM
CHRISPY's Avatar
Wow Mikey that is awesome! 9.6's in the fall ALL MOTOR?
Old Jul 27, 2003 | 06:23 PM
Fireball's Avatar
way to go mikey
Old Jul 27, 2003 | 07:52 PM
Joe Overton's Avatar
Way to go Mikey good numbers in the heat ..I'll vouch for TCS to they make killer converters...can't wait to try mine the other one was bad@ss as it was .... Mikey better start indexing the plugs, I'll be out in a week or so.
Old Jul 27, 2003 | 08:20 PM
Colonel's Avatar
Man that's an awesome ET...especially at that weight and in that heat!
Old Jul 28, 2003 | 10:58 AM
ChefBRD's Avatar
3273 ft. including Maple's 548 ft. elevation. Congrats Mikey, I used the 94 deg. even thought the track temp. had to be well above that where the air enters the air filter. When you watch the NHRA events they always give air temp and track temp. Yesterday the Seattle NHRA event had a 78 deg. air temp. and a ~110 deg. track temp when the sun was shining. I think they use track temp. to calculate DA but I'm not sure. Maybe there track temp. is actually about a foot above the actual tarmac. I'm sure when the sun is out the actual track surface at the start line gets very hot.
Old Jul 28, 2003 | 01:19 PM
mattf2's Avatar
so what does that run correct to w/ 3000+ ft ?
Old Jul 28, 2003 | 03:10 PM
Tom the roofer's Avatar
Your car is running GOOOOD Mikey. Awesome man.
Tom
Old Jul 28, 2003 | 03:37 PM
mikey's Avatar
LS1TECH Sponsor
Tom
Thanks alot Tom. Check out Cecil's schedule and see if you can make it here a day this fall. They have T&T's every Saturday from mid November to mid December. I don't even know if I will be able to race this fall. My daughter is playing county soccer (she's really good) and I agreed to help coach so that may eat up all of my spare time.
Mikey
Old Jul 29, 2003 | 12:40 AM
I will try and make it Mikey. I like Cecil. Good air.
Tom
Old Jul 29, 2003 | 08:02 AM
ScreaminSS01's Avatar
Tom
Mikey
Throw me the keys Might have to put your M6 back in because I wont know what to do with that weird shifter.
Old Jul 30, 2003 | 07:28 AM
ChefBRD's Avatar
9.65@138+ corrected
Mikey, are you running at the muscle car nats 8/23 and 8/24 at the Grove? There is a class for stock chassis NA cars up to ~530 ci. It's the Pro Stock class. Check out this link. www.fasteststreetcar.com
Old Jul 30, 2003 | 07:31 AM
ChefBRD's Avatar
Here's a description of the class:
TCI FAST Pro Stock is a naturally aspirated class designed for 1950 & newer American production cars and trucks that are equipped with stock-type chassis and 10.6" wide tires. Pro Stock entries are permitted small block and big block engines up to and including a maximum of 525 ci (depending on combination). Pro Stock permits a variety of race-proven modifications and performance enhancements on stock bodied, stock appearing vehicles. Suspension is restricted to stock-type or ladder bars.
Old Jul 30, 2003 | 11:53 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Cool! Bracket Race that Bad Boy!
Coach
Old Jul 31, 2003 | 07:19 AM
ChefBRD's Avatar
Coach
That might be a heads up class, I don't know for sure though.
Old Jul 31, 2003 | 11:20 AM
It is bracket racing with a 1/10 breakout.
Old Jul 31, 2003 | 11:24 AM
Silvr98z28's Avatar
Very nice. Congats.
Rich Andrews
