Drag Racing Tech
Tubes or screws with ETs?
Old Jul 28, 2003 | 02:28 AM
SmokinZed's Avatar
Default Tubes or screws with ETs?
Is there anyone running ET streets without screws or tubes? I have heard people go either way.
What is your experience?
Old Jul 28, 2003 | 07:00 PM
Wicked ls 1's Avatar
Default Re: Tubes or screws with ETs?
Not using either and youll find out that the general concensus around here youll only need screws if your spinning the tire on the rim Ive got a friend running slicks at 9.3 in the 1/4 and still no tubes they are screwed though.
Old Jul 28, 2003 | 08:11 PM
SmokinZed's Avatar
Ok cool, I think I should be ok than, thanks.
Old Jul 29, 2003 | 05:48 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run slicks at 15psi cold with no screws or tubes, but if you run your slicks at like 10psi you might need to screw them.
Old Jul 29, 2003 | 07:57 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
yep, mark your slicks and wheels with shoe polish/dial-in chalk and after a few runs see if they have moved. Tubes are extra rotating weight that are not necessary, unless you're like me and keep getting punctures in your et streets!
good luck!
Derek
Old Jul 29, 2003 | 08:27 PM
Navy David SS's Avatar
Ditto PSJ. I ran my ET Streets for 2 years without any problems (13-15psi) - no screws or tubes. Presently running ET Drags without screws to tubes (14.5 psi).
What I understanding either do both tubes and screws or neither. Don't do tubes without screws (you may damage the air tube); why screw without using tubes?
David
