What Rpm Do 6spds Need To Launch At???
my 60 ft is 2.5
wanting sugg on how to get out of the hole faster.
my fastest time was 13.6 @ 110 mph.
I'm being told w/my setup i should be in the mid 11's.
any help would be appreciated thanks guys
my formula has a moser 9" and spec 3+ clutch its a cam only car and leave on the et streets at 6800 and side step the clutch 1.51s all night long no bog so its really up to you
Honestly its impossible to say where you should launch. Track, suspension, tires, powerband will all influence your launch RPM.
I have launched as high as 7200, and and "low" as 5500 with the same suspension and tire, the difference was the air temp, and track/traction conditions.
Also, I do not recommend dumping the clutch, thats how parts brake, personally I slip the clutch very quickly, this lessens the shocks to the driveline as well as allows your RPM to stay up preventing a bog.
I have noticed that if I dump the clutch at 7000rpm with good track prep I can bog, but if I slip the clutch at 6000 or 6500 on the next pass I will come out of the hole smoothly and pull a good 60'
good luck!
1.37 60'FWIW with your combo and a good clutch, I'd shoot for atleast 6500. Also since you have the good parts DO NOT SLIP THE CLUTCH. All that does is cook the clutch and kill ET.
