Drag Racing Tech
qa1 tips and pointers...
Old Apr 5, 2008 | 11:06 AM
dkbmxer002's Avatar
Default qa1 tips and pointers...
i've got qa1 single adj all the way around on my car, i have a fully adj suspension by spohn. the car has a th400, 9 inch, forged 347 and some juice... it comes in around stock weight without me in it...
i know every car is different but what would be a good starting point for setting up the shocks?
Old Apr 5, 2008 | 11:51 AM
getusumws6's Avatar
3 up front and 6ish in rear is a good stating point. looks like your car has a rake to it.
Old Apr 5, 2008 | 11:32 PM
dkbmxer002's Avatar
yeah, too much for the track. it does fine on the street but weight transfer at the track isn't nice.
i'm going to lift it up to about a half an inch of rake
Old Apr 6, 2008 | 01:00 AM
chuckyt1's Avatar
Love the rake but... I ended up lifting my front about a 1/2 an inch to help at the track, (it was raked also). Not only is every car different but so is every track. I've gone as low as 1 on the fronts at the track... Try different settings and see what works for you on a given day...
Old Apr 6, 2008 | 06:55 AM
JL ws-6's Avatar
Race your car!
Start with the fronts on 3, rars on 5/6 stiffer on the right rear
Ya could lower the rear a touch, remove the bump stops if they're nto already gone and take the spring isolaters out, just put a piece of hose over the spring. That will drop the back 3/4 of an inch.
