going to the 1/8th mile tomarrow...
2000 Trans am M6
-Pacesetter longtube headers and ORY
-borlja adjustable catback exhaust
-231/237 cam (.595/.605) with pushrods and dual valvesprings
-ls6 oil pump -Fast 90/90 intake w/nick williams throttle body
-built T56 (t56rebuilds)
-Pro 5.0 shifter
-spec stage 3 clutch and aluminum flywheel
-chromoly driveshaft
-Qa1 adjustable front and rear shocks and springs
-BMR torque arm
-BMR panhard bar
-BMR weld in subframe connectors
-BMR driveshaft loop
-9" w/ aluminum centersection
-35 spline axles w/ spool
-3.73 gears
I will be on BFG drag radials, temp tommarow is going to be 45-50 degrees and i consider myself a good driver.... what do you guys think? i will have results with vids tomarrow
