Launching tips/ QA1 shock settings
I was on MT et streets @ 14lbs on weld draglights but was unable to use my skinnies because my front studs were not long enough.... I was launching at around 4k rpm's, i tried launching around 5k and i lit them up big time
here is my best slip:
the majority of my 60 foots were in the 1.95 range
here is the run
http://www.youtube.com/watch?v=FMm1CKAmku8
so any help as to some launching techniques, settings for the shocks, air in tires etc etc?
awesome runs for the first time out with it. Get that 60 ft down and you'll be in the 11's in no time.
If it hooks good stiffen the front shocks one click at a time to take out unneeded front lift one click at a time until you get the fastest 60ft.
I start with Front QA1R's 1/1 Rear QA1's 6/6 and 14 PSI in drag slicks for the first pass off the trailer. I then adjust from there depending on track and how it hooks.
This 11.83@117 run was a 1.6 60'
Shocks F1/1 R6/6
Tires F35 R14
Spun off the line
