Drag Racing Tech
Bolt in/Weld in rollcage install, how much on average?
Old Aug 3, 2003 | 02:28 PM
NassyVette's Avatar
Default Bolt in/Weld in rollcage install, how much on average?
I've got a 6pt weld in cage from wolfe racecraft. Anyone know how much I should be expecting to pay for this install, and does anyone know someone in the chicago land area that could do it?
Old Aug 3, 2003 | 03:05 PM
Scalpel's Avatar
Default Re: Bolt in/Weld in rollcage install, how much on average?
You need to post this in the Chassis/Body section. However, I can tell you that if you strip out the interior, carpet, etc and drive it to the place with that stuff not there, it's less labor = cheaper for you.
Old Aug 3, 2003 | 04:43 PM
WicketMike's Avatar
i got quoted 200 for bolt in and 400 for weld in.
but i think im getting a deal
Old Aug 3, 2003 | 07:26 PM
Cal's Avatar
Cal
I welded mine in myself, one hellva big job. Make sure you tell them whether you have mild steel or chromoly, since the the welding process is different between them. It is not obvious looking at the metal which you have.
