11.99 possible?
With the mods you have, and the gears, weight your car is and with the tires you're going to run assuming everything is working right I would say it should break 11.99
I think you could get away with running a 26" tire, but if you're going to run a 4.30 and don't have a cam I think the 27" would help so you don't run out of gear.
111 mph is would be close to the 11.99 depending on how good the car hooks. If you added a cam and got the chassis to work right and had the right gears it would go much faster than 11.99.
