Gear change, 60'?
Full UMI Tubular Poly rear suspension
255/50-16 MT ET Streets w/ psi from 22-27 any lower and wheel hops
Relocation brackets, lowest hole, middle hole wheel hops
Stock Converter
3750 or so raceweight
at 27psi the drag radials chirp off the line but don't really spin. Could I use more psi? Is there any being left on the table without changing the converter or weight? Thanks guys and girls for any insite. BTW, pic in sig is last season w/ nitrous and no gears.
