Drag Racing Tech
Too much "play" in my RT TA?
Old May 6, 2008 | 04:09 PM
TS6's Avatar
TS6
Default Too much "play" in my RT TA?
I pulled the rear end out today and inspected my torque arm while it was out. Last year I noticed I had some up and down play in the TA assembly. Basically what I'm seeing is that the TA can move up and down on its bracket, like the holes are too big. Is it supposed to be this way or are the holes enlarged from wear?
With the rear end mounted I can move the front of the torque arm (where it mounts at the tranny) up and down about 1-1.5".
Old May 6, 2008 | 04:28 PM
SPEEDYws6's Avatar
Thats a bunch of play! Sounds like the bolts were loose and wore out the holes. Mine was never like that, but I didn't get many passes out of it before it bent.
Old May 6, 2008 | 04:40 PM
TS6's Avatar
TS6
I hate to spend more $$$ but this might be a good time to get a CM TA. Maybe someone has a nice used one?
Old May 6, 2008 | 06:02 PM
kp's Avatar
kp
If the arm is moving and the bracket is not I would sure take it apart and see whats worn out or broken because thats not right at all.
Old May 6, 2008 | 07:33 PM
TS6's Avatar
TS6
The holes in the bracket appear to be egged out a little. One bolt was not tight when I removed it, I figure it must have been moving and wearing the hole out.
I'm going to weld some new material there and re-drill it. I was gonna buy a new T/A but its really not gonna do much for me and the CM ones are kind of expensive for a few lbs difference.
Old May 6, 2008 | 07:35 PM
kp's Avatar
kp
I'm still using a random tech arm, been on the car for four years.
You can probably buy a new bracket from them I'm sure if yours is really bad.
