help me launch *VIDEO*
5k dump and the front end pops up and falls
http://videos.streetfire.net/video/c...nch_156085.htm
I recommend nitrous
try more rpm when you dump the clutch or even better imo is do a very quick slip as opposed to a dump...instead of side stepping the cluth raise your foot straight up with the clutch...will not be as fast and give it a slight slip that will help with the bog
.....either leave higher off the line or add some power. I didn't see it in your sig but do you have lower control arm relocation brackets? if so move the lower control arms up to help take some bite out of the car. You could also try running a higher air pressure in the tires to maybe get spin so it would bog so bad.....my .02
