Roll bar question
I'm only 5'0 tall
So my seat is mounted very close to the steering wheel.
What do I do??
You can move the main hoop foreward some, that is your only real option. You need a 6 pt too, that 5 pt is for nhra, epping won't like it.
We are moving it alittle bit in but not much. Don won't be able to drive the car if I move it too far
The 5" rule they are talking about hight wise means that the two rear bars that go into the hatch area, can not be mounted lower than 5" from the top of the main hoop.
So being short is ok as long as the bar is moved forward.
Marco, if your only going with a 6 point and don't plan to convert it to a 10 point at any time, then you could probably get away with being more than 6". The car doesn't have to be certed or even gone over that well unless your getting a permanent IHRA number for the year. So they probably wouldn't check it in the general tech lines. If your running mostly at NED, maybe give Joe a call and tell him what the situation is.
Edit: Lol, you could do like my dad used to do circle track racing. He used to tape pink hard foam blocks to his boots in order to reach the pedals. Him and his good friend used to run the same Super Stock car.
