Drag Racing Tech
anyone running this setup?
Old Jun 2, 2008 | 11:01 PM
SSIRBY's Avatar
Default anyone running this setup?
3800 converter, 9" w/ 3.50's, 28/12.5/15 et street. power i'm running is in my sig. what kinda times out of this? full weight car. how bad are the 28" tires gonna hurt with such tall gears? if ya need more details, ask me.
Old Jun 3, 2008 | 12:56 AM
RAGENZ28's Avatar
Spray the car, it'll haul ***, end of dilemma.
Old Jun 3, 2008 | 06:11 PM
SSIRBY's Avatar
i know for sure it'll haul on the kit, just wanted to know what it would run NA.
Old Jun 4, 2008 | 01:12 AM
358chevycamaro's Avatar
I am running a 3.42 in a 7.5 10 bolt ona 26/10.5/15 et drag. Not exactly what you asked for but no one else has spoke up sooo....
Anyways I ran a 7.30 @ 95.94 on a 1.66 60' with almost no suspension on a 347" motor. Hope that helps!
Old Jun 4, 2008 | 03:55 PM
NOSJNKY's Avatar
Same power as you(474RWHP) full weight WS6,408,TH400, 9" with 3.50 gear. Best NA pass was 10.71@123mph on 325/50 MT drag radials. Had a 4200 converter in at the time, tightened it up a little since then but havent ran it on motor again.
Old Jun 4, 2008 | 05:58 PM
BAKED's Avatar
I had a 3800, TH-400, 9: w/3:55's making around 430rwhp but the car was probably around 3100 lbs and had 325-50-15 M/T ET street radials. The car ran 11.teens with that setup on motor and 9.7's on the 200 shot.
I had the converter tightened up and went to a glide this year, it KILLED my N/A times but should be perfect for the 350+ shot.
Hope this helps.
Old Jun 4, 2008 | 08:23 PM
SSIRBY's Avatar
ok thanks guys. i was just wondering. sounds to me i have more of a spray setup. well, i'm fixing to have 4.11's installed but the same converter. so my ets should pick up some, but really haul on the kit.
Old Jun 4, 2008 | 08:26 PM
SSIRBY's Avatar
what brand was your 4200?
Old Jun 4, 2008 | 08:46 PM
NOSJNKY's Avatar
We have a local shop here(torque converter services) that builds converters. They do the majority of "performance" applications around here. Also makes it much easier to have the converter tightened/looosened without having to ship it off.
Old Jun 5, 2008 | 12:28 AM
SSIRBY's Avatar
did you ever spray the 4200? or was it mostly for NA?
Old Jun 5, 2008 | 06:01 AM
NOSJNKY's Avatar
We did spray it with a small shot a couple of times but ran through the converter.the best it ran like that was 10.17@128mph.
