Drag Racing Tech
Should I get slicks?
Old Jun 4, 2008 | 11:15 PM
BLK85's Avatar
Default Should I get slicks?
I dont run that fast 12.65 with worn out DRs. When I get to the strip I switch out tires so I dont really care to much about driving to the track with the tires and running my time(I do drive to the track though). The only downside is not being able to run the street classes and having to run the VERY competitive classes. What is everyones opinion on this subject?
Old Jun 5, 2008 | 12:00 AM
RAGENZ28's Avatar
If you swap the tires when you go to the track and don't drive on them on the street, run the very best tire you can for your setup.
Old Jun 5, 2008 | 06:05 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
I agree with Ragen's statement, but if the car will hook on drag radials why not run them? The car will likely run a tad quicker due to the radial's construction versus a slick, and as mentioned it opens up your class choice.
Old Jun 5, 2008 | 11:08 AM
MetallicaMatt's Avatar
What DR's are you running?
If you were running Nittos or something, maybe setup to an ET Street? Still will put you in the DOT class...
Old Jun 5, 2008 | 01:36 PM
HSESWS6's Avatar
M6.... Stock rear still? I would go with the MT Street Radial or maybe an ET Street but you will be pushing it on a 10 bolt IMHO.
Old Jun 5, 2008 | 06:33 PM
BLK85's Avatar
BFG TAs
Nope Ive got a a 12 bolt with 4.11 gears and a bunch of suspension.
Old Jun 5, 2008 | 06:44 PM
RAGENZ28's Avatar
Drag radials don't work very well with stick cars, they are much more favored to a auto.
