Bracket racers inside (cooling question)
I'm thinking on going with a single cooler with a fan that turns on around 170*, but that would only work while the car was running so the fluid is being pumped through the cooler. How do you cool off the tranny between rounds? Any tricks? Any help would be appreciated!
My Nova never gets above 180 on the gauge in pan on a TH400 with a 3800 stall 10" even lapping it 5 minutes between rounds.
All I can think of is a fan (as mentioned), running a bigger single cooler as far away from any other source of heat as possible in good airflow, or you can spray the cooler down between rounds with water and/or nitrous.
Derek
We also have a 6.0 iron block that doesn't disipate heat very well. Make sure your fans are coming on as programmed. I had a relay go bad once that s/d one of the fans and it ran much hotter than normal.
Engine temp is critical to being able to run the number.
G/L and Keep us posted.
http://www.chiseledperformance.net/transcooler.htm
Coach
Keep us updated.
TXCAMSS how and where do you hve your cooler mounted? If I remember correctly you have the same ram air setup as I do (2 holes in the front ducted to the intake/lid)
For ours to keep heat out we do all kinds of things. Tranny cooler, synthetic fluid, once we get deep in rounds we put a leaf blower under the car directly on the pan and you wouldn't believe how much it helps.
I'm still having issues. I changed the temp gauge, sending unit, and went with a cooler/fan setup infront of the radiator. I even cut the front out (pic) to make sure it gets plenty of air. Don't worry I have the SLP SS grill to cover the front when I get this figured out
Here is the cooler I went with: http://www.jegs.com/i/Perma-Cool/771/12311/10002/-1
I figured it would be plenty, but I am still having overheating issues. I'm using the stock hard lines to about 12" from the cooler then 3/8 hose. Would a larger diameter line help?
Any help would be greatly appreciated!!!
I don't know the finish line 1/4 mi rpm/mph yet. I have only ran it 1/8 mi so far. In the 1/8th it ran 98.06 mph @ 5900 rpm in 3rd with 4.10 gear and 28" ET Drags. Is there a way to figure converter slipage in the 1/8th?
