Drag Racing Tech
1995 camaro wont 60ft..
Old Jun 27, 2008 | 09:53 AM
383racecar's Avatar
Default 1995 camaro wont 60ft..
Well i got a 1995 camaro weights 3650 with me in it, Its 383le2 heads cam,on a 250shot,with a th350 4300rpm on the trans brake,its got a custom torque arm with a 8.5 diff the torque arm is a copy of a bmr moded to work on a 8.5 diff, has lakewood LCA, 3.73 gear and 26-11.5-15QTP. best 60ft is a 1.48 with this setup and my all stock susp. with a 4l60e and 7.5 with a 200dshot off the foot brake did 1.48s. i was thinking it should be able to do 1.3X 60s??also pinion angle is set -2degrees. best time to date is a 10.13@135.91 with a 1.54 60ft.
Old Jun 27, 2008 | 09:58 AM
RAGENZ28's Avatar
Do you have relocation brackets, can you adjust the hight of the torque arm, do you have adjustable shocks, do you have front drag springs?
With your power level it's time for more adjustment options on the chassis. I'd start with getting adjustable shocks.
Old Jun 27, 2008 | 10:41 AM
ty_ty13's Avatar
7 Second Club
sounds like it has too much torque multiplication....
th350 has a 2.5x first gear i believ and you have 3.73 in the rear and a 26" tall tire...
a 28" tire would probably make a night and day difference...
Old Jun 27, 2008 | 10:50 AM
kline454's Avatar
I would try more tire.
Old Jun 27, 2008 | 10:53 AM
383racecar's Avatar
Well sorry i forgot to say i did try 28-11.5QTP and had the same 60fts....
Old Jun 27, 2008 | 11:18 AM
Indukted1's Avatar
LS1Tech Sponsor
I would try to drop some weight out of the car i know that will help out on the 60ft..Theres alot of things that could be a factor tire press, has the susp ever been set?
Old Jun 27, 2008 | 11:31 AM
JL ws-6's Avatar
Race your car!
Several things that you can do to help. I would first start by getting a set of ET drags, 28x10.5S ONly reason I say that is because they are a known to alot of people on here and they just work in general on everything.
Are you stalling the car up any, just flashing the converter, leaving off a transbrake, and if so at what rpm?
Do you have any video of what the car is doing? Have someone watch the car when you leave the line, does it spin, does it go but just bog? How is the nitrous wired, is it wired to work right off the transbrake?
More info needed.....
Old Jun 27, 2008 | 12:31 PM
383racecar's Avatar
Im coming off the T-brake @4300rpm and the nitrous is set to come on as soon as you let go of the brake, i will try to post a video but the tires are turning no bog, i was looking into some MT 28-10.5 i think that will be the next set i get after these are worn out. im running 12-14psi in the tires.
Old Jun 27, 2008 | 12:43 PM
JL ws-6's Avatar
Race your car!
Tire pressure seems about right, I've found that heavier cars like more pressure.
If the car was bogging I'd say add 2 lbs to stop that, if it's spinning, until you get some adjustable shocks on the car the only thing you can really do is play with air pressure, messing with the pinion angle really won't solve the problem.
Have you ever tried leaving off the footbrake? What does the car do if you hold it just above idle and smash the gas pedal? (nitrous comes on @ WOT only but not when the transbrake is on )
Old Jun 27, 2008 | 12:56 PM
ty_ty13's Avatar
7 Second Club
try delaying the nitrous about .4seconds in... see what happens
Old Jun 27, 2008 | 01:39 PM
383racecar's Avatar
foot braking 60fts are the same as trans brake it hooks better but bogs a little. So it sounds like its time for some QA1s
Old Jun 27, 2008 | 03:05 PM
RAGENZ28's Avatar
If you go the same 60ft as you do foot braking on the transbrake your suspension setup is junk.
Old Jun 27, 2008 | 03:45 PM
TwoFast4Lv's Avatar
If it was any thing like mine before we re did it the car was just blowing the tires off. to much power not enough suspenion. I was going through to 60ft consistant 1.45s sideways
Lighter and more adjustments. Madman solved my problems
Old Jun 27, 2008 | 04:54 PM
RAGENZ28's Avatar
+1 call MADMAN on the phone 225-673-3533, give him all your detailed info and pay him what he asks to dial in your car. It cost to go fast, pay to do it right and get it done. You can ask people on here all day that don't know their hand from their ***, pay an expert. That's my opinion.
Old Jun 27, 2008 | 08:40 PM
383racecar's Avatar
QUOTE=RAGENZ28;9637482]If you go the same 60ft as you do foot braking on the transbrake your suspension setup is junk.[/QUOTE]
yea i think your right just got back from the track, tryed coming off the trans brake on the 250shot, car went stupid sideways and had to shut down then, i tryed foot braking went 1.63 60fts then tryed coming out on motor then sparying went 1.70, so it needs more tire and more susp.. my friend thinks im not going to be able to hook a 250 off the brake, even with a 28-10.5m/t and more susp. i guess im going to try and get some tires and QA1s to start with,
Old Jun 27, 2008 | 10:14 PM
JL ws-6's Avatar
Race your car!
you may have to put a delay on a shot that big, either that or tighten the converter up.
Old Jun 27, 2008 | 10:51 PM
383racecar's Avatar
The conveter is way tight im going to get it reworked this winter More stall motor it sucks and on spary it still alittle tight if it would hook,but first is QA1s and more tire.
Old Jun 28, 2008 | 03:35 AM
TwoFast4Lv's Avatar
Here was my night. Finaly got the miss gone(opti imagine that)
My night was filled with 1.4x 60fts N/A with only 420RWHP on tap.
All I did was call MADMAN
Old Jul 8, 2008 | 04:20 PM
383racecar's Avatar
well after some looking around i found that my lower control arms are 4 degrees up in the back i dont have relocation brackets should i install them? i know higher h.p cars you want the lca flat and lower h.p cars hook better with them on the lower holes, but mine are up higher than stock for some reason.
Old Jul 8, 2008 | 04:50 PM
MADMAN's Avatar
LS1Tech Sponsor
You never want the lcas running uphill to the rearend. Also your convertor is way too loose on the NOS. You need to tighten it up.
__________________
www.madmanandcoracing.com
225-343-9029
