Drag Racing Tech
Anyone use a fuel cooler?
Old Jul 6, 2008 | 07:47 PM
TS6's Avatar
TS6
Default Anyone use a fuel cooler?
Did a search, couldn't find much. Has anyone tried using a fuel cooler for a street driven high HP car with a big pump? Any results?
Old Jul 7, 2008 | 09:49 AM
ty_ty13's Avatar
7 Second Club
if anything i'd heat the fuel....
Old Jul 7, 2008 | 11:23 AM
thunderstruck's Avatar
why is that ?
Old Jul 7, 2008 | 01:40 PM
ty_ty13's Avatar
7 Second Club
i'd want it as close to combustion temp as possible.... you can always add more injectors if your after volume
Old Jul 7, 2008 | 03:04 PM
TS6's Avatar
TS6
No, heat=bad. Especially for the pump.
Old Jul 7, 2008 | 03:19 PM
rocketman442's Avatar
I've seen alot of carbed guys do it but I have never seen it done on fuel injection. That is if your talking about the cool can(ice in a can with fuel line running thru it) I would be interested in the results myself.
Old Jul 7, 2008 | 03:47 PM
TS6's Avatar
TS6
Not a cool can, a cooler, like a trans cooler.
Old Jul 7, 2008 | 05:07 PM
ls1king000's Avatar
Here's a nice fuel cooler with electric fans
http://www.cardomain.com/member_page...168_4_full.jpg
Old Jul 9, 2008 | 03:25 PM
87Lt1Monte's Avatar
Heat the fuel?? holy cow what good would that do?
Old Jul 9, 2008 | 07:20 PM
Ari G's Avatar
Cool the fuel to cool the IAT ect..
Old Jul 10, 2008 | 07:05 PM
DADDY&GIRL93TA's Avatar
Same here haven't seen a Fuel INJ Car with it yet only carb guys.I recall there was one guy years ago that keep his gas can on ice at the track
Old Jul 10, 2008 | 07:21 PM
Im gonna try it one day but it will probably be a year or two till I get around to it.
Old Jul 12, 2008 | 05:15 PM
daniel6718's Avatar
heated fuel burns better and cleaner....i dont se why you would cool it?
Old Jul 12, 2008 | 05:48 PM
WE TODD DID's Avatar
If you heated fuel to combustion temps, I would think it would evaporate, or boil.
Old Jul 12, 2008 | 05:49 PM
Phil99vette's Avatar
7 Second Club
Certain fuels don't want to be hot, get the fuel cool and adjust timing accordingly.
Old Jul 12, 2008 | 06:06 PM
MeentSS02's Avatar
Kleeborp the Moderator™
What do you think it does when it hits a hot intake port or valve?
Old Jul 14, 2008 | 09:36 AM
Ryan K's Avatar
Pathological Modifier
Lets see, numbers of reasons to NOT heat the fuel:
1. Your fuel pump actually pumps less fuel when its hot, fluid is less dence.
2. Heated fuel is more likely to cavitate in the pump causing erotion of the pump gears
3. Vapor lock, pump may cavitate to the point of not pumping at all
4. Hotter fuel is more likely to preignite, Ping
Ryan K.
Old Jul 14, 2008 | 09:51 AM
The Manalishi's Avatar
Heat the fuel WTF??
I'd be interested in seeing the effects of cooling the fuel on an injected car as well.
Old Jul 14, 2008 | 11:59 AM
Matt D's Avatar
Retired Street Racer
e85 for the win!
Old Jul 16, 2008 | 09:53 AM
ty_ty13's Avatar
7 Second Club
people dont know that some of the prostock teams used to do this before it was outlawed... of course its not for the street car... race car only that runs 1/4 mile then shuts off... and ofcourse its certain fuels to a certain temp not a boiling temp... but pretty hot
