Drag Racing Tech
Price Increases
Old Jul 11, 2008 | 08:24 PM
TwoFast4Lv's Avatar
Originally Posted by JL ws-6
Some truth to that. I just bought 40 plugs (5 sets) the other day, 108 bucks.
Yeah I ordered a case of AR 474s and by the time they got here they were over $5ea! Sent those puppies back!
I did pick up a case of 473s for $70 delivered
It is tough right now that is for damn sure. Hell I had to get a day job again to suport my racing LOL!
Old Jul 11, 2008 | 09:50 PM
JL ws-6's Avatar
Race your car!
what plugs are you running? Not farmiliar with those #'s and the case that you buy, how many are in it?
I run an autolite AR3933 plug, and they're usually about 2.7x a piece depending on where I get them. But with my setup a set usually gets me thru the day no problems.
Old Jul 12, 2008 | 12:09 AM
TwoFast4Lv's Avatar
I am still using stock heads.
AR94 is a projected heat range 7
AR93 is a projected Heat Range 9
AR474 is a NON-projected Heat Range 7
AR473 in a NON-projected Heat Range 8
I was using the Projected plugs and they were working well on the track and street but everyone keeps saying to use the NON-projected plugs so I am trying them
I think I paid $2.49Ea for a dozen AR474s today local. Always looking for a good hook up. Still dailing every thing in.
Hell between Fuel and Plug My wife is going to have a cow when I have to call Madman and order a new set of 325s
Old Jul 12, 2008 | 05:35 AM
JL ws-6's Avatar
Race your car!
I wanna put a set of 325/50's on my car, but with the problems I've had getting the car to leave on the 28x10.5S et drag (no limiters = goes on the bumper, limiters = spins for a foot then goes) I dunno if the car's close enough to work with the radial yet.
Last year i tried a set of goodyear radials, couldn't leave off the transbrake AT ALL, had to run off the footbrake, and went decently fast doing so, but now with the nitrous, I dunno if it's set up good enough yet.
Sucks, because I have a race that's coming that's 5 grand to win that requires radials, and another race that if I had DOT tires on the car I could ener a different class that I'd probably really crack some skulls in, but I am really a little shaky about putting a set on right now.
That, plus I'd have a good bit of cutting/work to do to get the 325/50 radial on the car, which is the least of my concern at this point.
Old Jul 12, 2008 | 08:29 AM
MADMAN's Avatar
LS1Tech Sponsor
Originally Posted by TheBlurLS1
Can you give me the skinny on 315/35/r17 MT DR's?
What I have been told by MT is that the 15" stuff is so popular they cant make the 16 or 17" stuff right now.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jul 12, 2008 | 01:46 PM
ATVracr's Avatar
Thanks Madman.
JL, you guys shuld try the NGK 9's or 10's they are alot easier to read and may save the motor if you make a mistake in the tune.
Old Jul 12, 2008 | 04:20 PM
JL ws-6's Avatar
Race your car!
I was on the NGK's #9 initially and was able to get the tuneup pretty close, still a touch on the rich side (I know that can be as bad as too lean, but I'm talking the a/f is in the mid to low 11's) then I went to the autolite plug.
The autolite plug is alot tougher you're right, but they'll go a whole day and run good, and they don't seem to foul out as bad. I've read them and they real pretty much the same as the NGK does, but it takes a good 2 runs to get a heat mark on the strap unlike the NGK that I can read after one pass.
I'm still on such a small shot, that to hurt something I'd have to be WAY out in left field with something, until the fogger goes on I am pretty safe as it sits right now.
Old Jul 13, 2008 | 08:08 AM
darrensls1's Avatar
I need new M/T street radials. If I didn't want to wait for them to get around to making more 255/50/16's then what size rims do I need to buy to use a 15" tire?
Old Jul 15, 2008 | 12:41 PM
camarokid94's Avatar
do you have any 26s 10.5 15s to 66502 bussiness
