ABS Delete - Any computer changes required?
Or does it just bolt on and go w/o throwing any codes or causing any other problems?
How does 3 channel reluctor ring fit into all this as well? Is it useless after ABS delete? Can you then go w/ just about any rear end you want that will physically fit?
As for the rear, if you want you can get whatever you want that fits the car. Just be sure if you have a 3 channel you don't just pull the plug or you will have an unsealed rear...
You can put any channel rear or any tire configuration on your car and not affect normal braking performance after modding your ABS system with our kits. Actually, you have control over brake bias since every one of our kits include an adjustable proportional valve.
pin 7 to pin 12 turns the ABS INOP light off.
pin 16 to pin 12 turns the BRAKE light off.
Pin 12 is a ground so you are grounding these wires out, and it turns off the light. Much better then pulling apart dash and brekaing/taping bulb.
That info came from steve @ sjm and i run his abs delete kit on my car. Works and looks great. For other year fbodies i dont know if wirring is the same.
Chris
Chris
https://ls1tech.com/forums/showthrea...518&highlight=
