Drag Racing Tech
Rim Screw Question
Old Aug 4, 2008 | 11:17 AM
code4's Avatar
Default Rim Screw Question
Anyone ever drilled their rims with the tires already mounted?
I have a race & a short time to get this done.
Old Aug 4, 2008 | 12:03 PM
N2RACINGLS1's's Avatar
Yes, All I did was add a rubber hose that was just a little shorter then the drill bit. The rubber hose prevents you from drilling to far. I had no problems.
LM97Z's Avatar
I did, just take your time & go slow ( use a variable speed drill) untill you see rubber, then install some tape on the bit so you know how far to drill for the rest.
Old Aug 4, 2008 | 12:04 PM
code4's Avatar
Thanks guys! I'll go try it right now.
Old Aug 4, 2008 | 01:20 PM
dlove's Avatar
just did mine. just go slow and once you get close slow down even more and the bit will catch at the end. Then go just enough to remove the final layer. Doing it this way I had no problems and hardly even nicked the tire with the drill bit.
be sure to add some air to the tires to help hold them against the rim
Old Aug 4, 2008 | 03:02 PM
code4's Avatar
Already done. I used 20 lbs of air, it went pretty good.
I wonder if I should have them balanced now?
Old Aug 6, 2008 | 02:23 PM
chvypwr31's Avatar
ya u need 2 get them balanced theres more weight on it now in different spots.
