Drag Racing Tech
Anything else to pull while pulling front bumper reinforcement?
Old Aug 12, 2008 | 08:17 AM
maggiemike's Avatar
Default Anything else to pull while pulling front bumper reinforcement?
I'm pulling my front bumper reinforcement off right now. is there anything else I can pull out at the same time? thanks
Old Aug 12, 2008 | 01:09 PM
Ericbigmac83's Avatar
Have you read the weight reduction list? Thats a great place to start and see how extreme with weight reduction you want to go
Old Aug 12, 2008 | 04:38 PM
WMSuperSport's Avatar
Just off the top of my head, you can eliminate the windshield fluid reservior and pump, foglights and brackets, maybe more
Old Aug 12, 2008 | 05:02 PM
BlackWS666's Avatar
Just did mine last week. You can cut the horns off the frame(where the support bolted to) and also remove the actually horns if you dont care about those. Along with inner fender plastic, and one other piece of plastic support that holds on the front bumper at the bottom. My total weight removed was right at 38 pounds.
Old Aug 12, 2008 | 06:03 PM
Fast_94_Z's Avatar
i would just hit up burkhart and get a front bumper support from them and eliminate it all together.
Old Aug 12, 2008 | 08:51 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Frame horns are around 5 lbs, fog lights, horns, windshield wiper fluid resevoir, and you can cut part of the core support.
