Drag Racing Tech
Kirkey Pro Drags does this look safe???
Old Aug 20, 2008 | 10:43 PM
DopeFedZ's Avatar
Default Kirkey Pro Drags does this look safe???
I have a set of Kirkeys I really want to replace my stockers with. For the life of me I can't figure out how to mount these up because of the curved bottom the seats have. I have a pair of Corbeau brackets with sliders. Below is the only way I can think of bolting them up. Does it look sturdy let alone safe? The only other brackets I have seen that may work are Ed Quay ones but they are like $175 for just the driver seat.
I would prefer for them to be adjustable but this is all I could come up with. I would be putting bolts through the white dots marked on the brackets.
Old Aug 20, 2008 | 10:53 PM
DopeFedZ's Avatar
I could weld another piece of metal in between the bottom like the picture below and use a couple more bolts there?
Old Aug 21, 2008 | 05:59 AM
MADMAN's Avatar
LS1Tech Sponsor
It will work. Put that other piece in and you will be fine.
__________________
www.madmanandcoracing.com
225-343-9029
Old Aug 21, 2008 | 09:53 AM
Ryan K's Avatar
Pathological Modifier
Don't forget to be legal at the track, you'll need it mounted to the crossbar of the rollbar.
Ryan
Old Aug 21, 2008 | 04:38 PM
DopeFedZ's Avatar
Thanks guys I'll give it a try.
Old Aug 22, 2008 | 06:45 AM
tektrans's Avatar
That's alot of metal under there, too bad because I'm sure it weighs some.
The guy that did mine basically used a thick piece of round bar, one in front and one in the rear and welded tabs for the floor and seat bolts. pluse the roll cage mount of course. PM me your email if you want and I'll shoot you over a couple of pics of the set up. It looks real simple to make.
-Mark
Old Aug 22, 2008 | 07:58 AM
JL ws-6's Avatar
Race your car!
I mounted mine right on the back 2 stock seat studs, and attached it to the rollbar.
Seat is as solid as can be, gave me a bunch more head room too, with them up anymore I'd be beatign my head on the rollbar really bad, it's bad enough that the padding touches my helmet if I'm not sitting as low in the seat as I can.
Old Aug 22, 2008 | 01:39 PM
DopeFedZ's Avatar
-Mark
Sent you a PM.
Old Aug 23, 2008 | 03:38 PM
DopeFedZ's Avatar
Just finished up this is what I came up with. Not much adjustment but the way it is now is perfect for me.
Old Aug 23, 2008 | 07:43 PM
tektrans's Avatar
I don't think that seat is going anywhere, hehe. You got it covered for sure!
Sent you the pics, one day I'll figure out how to post pics on here.
