Drag Racing Tech
New Setup......
Old Aug 24, 2008 | 10:39 AM
walker94z28's Avatar
Default New Setup......
Well I had a little misfortune with the setup I had so I had to take it out. I found some metal in the oil pan and it was smoking at startup so I decided that it was time to remove it and build something better. When my boys at the best shop in the world " Tubbs Automotive " got it out they discovered that the windage tray was being hit by the rod bolts and that the number 7 exhaust valve spring, the inner spring and seat was gone and in the oil pan. Well, thats all for that one. Here is my new setup.
Same block, LS2
Eagle 4.000 crank
Scat H beam rods.
Diamond -2cc pistons
TSP Texas Giant camshaft
Now for the changes,
PRC stage 3, 6 litre heads.
Taking the heads down to 64cc from 72cc.
All new guides and valve springs. 2.08, 1.65 is the valve size
The stock LS6 intake and injectors are being replaced with
Profesional Products 96mm typhoon intake
90mm throtle body and 42lb injectors.
The stock K member is being replace by a tubular BMR
Lowering the rear 1 inch and putting on adjustable shocks.
8 point roll cage is being installed as well.
I will be putting on a diffirent nitrous setup as well. 2 stages
The A.C, power steering , and ABS pump are all being removed.
Special thanks to Marty, and Larry Tubbs at Tubbs Automotive....
Also a shout out to Jon Reynolds at Texas Speed for answering all of my questions and taking the time to help. Thanks alot....
Let me know what you think......
