Drag Racing Tech
17" dr question
Old Aug 25, 2008 | 08:07 AM
aaronbetzner's Avatar
Default 17" dr question
What pressure should I run at the track and what is the best method for launch with sig. mods?
Old Aug 25, 2008 | 10:12 AM
Bitemark46's Avatar
You have to play with the pressure depending on track prep. But I'd start at 15psi cold (17psi hot). As far as launching, try around 3k with a quick slip of the clutch, not a dump. If it bogs or spins adjust the launch rpm by 200.
