wether you need lowering springs or stock springs will depend on the power, gear ratios, type and size of tire, launch rpm, transmission type, etc, etc. what works for one guy won't necessarily work for another. generally, a shorter, stiffer spring would be for a higher powered, hard launching car. it's mostly about the car's center of gravity. higher powered, faster cars generally need a lower c.o.g., a mildly modified(say 9-11 sec) cars will use a higher c.o.g. for drag racing, most people here will find the stock springs will work just fine. as stated above... you will more than likely find better results with a good set of shocks on the car. weight transfer is directly controlled by shock valving(as well as a few other things).
