Drag Racing Tech
dash removal
Old Aug 26, 2008 | 05:21 PM
transamsam98's Avatar
Default dash removal
can anybody help me figure ot how to get the dashapart please
Old Aug 26, 2008 | 06:39 PM
TheOutlaw1's Avatar
What part do you need help with?.. Are you taking the dash out for a cage?
Old Aug 26, 2008 | 06:40 PM
TRMIN8R's Avatar
Its not too bad, the top plastic piece just pops off, then there are some bolts that hold the top of the dash in. The bolts that hold the dash in from the bottom are fairly easy to get to, there is one bolt behind the radio that is a bit of a pain to get out. Then unplugging all the **** behind the dash is kind of a bitch. But taking it out should take about 2 hours or so.
Old Aug 26, 2008 | 06:42 PM
smokeum99ta's Avatar
I'm local (waldorf) if you need a hand. Just pm me if you want to meet up.
Old Aug 26, 2008 | 06:58 PM
well I will be removing it or a cage laer on but at the moment I am tryng to trace some wires and remove them for some lbs drop. aso it will make custom stereo wiring alot easier as well as removing the last of the ac system.
Old Aug 26, 2008 | 09:58 PM
87Lt1Monte's Avatar
Im close to you.. PM me if you have any questions ive done it 2 times
