Drag Racing Tech
help me with wheel hop!!!!!
Old Aug 26, 2008 | 11:27 PM
shaun's Avatar
Red face help me with wheel hop!!!!!
hey guys i need some help with seting up my car.
i have replaced every thing except the panard bar.
i have a edelbrock aj ta set at - 1/2 degree pinion angle=lakewood lca's=hypercoil springs and bilstien hd shocks= bmr lca brackets= 17x9.5 zr1's with 275 nitto drags.
im geting some wheel hop and its killing my 60ft i run about 20 psi in the nittos at the track and i do a good burn out to warm em up.
my lca's are on the lowest hole on the drop brackets.
do i need a little more pinion angle? from what i see on here - 1 1/2 to 2 is what i have been seeing on here.the wheels hop aint that bad i seems to feel like it will hop a few times then hook.
help me out guys and thanks.
Old Aug 26, 2008 | 11:31 PM
waterbug1999's Avatar
I would lower the pressure a little more... See if that helps.
From my own experience, the LCA relo brackets did the trick for me.
Old Aug 27, 2008 | 11:39 AM
shaun's Avatar
thanks. any one else?
Old Aug 27, 2008 | 12:07 PM
omcar's Avatar
I have Hotchkis lower control arms, Random Technology adj. t/a set at -2 1/2, QA1 adjustable rear shocks and M/T drag radials set at 20psi. Launchs good.
Old Aug 27, 2008 | 12:58 PM
LM97Z's Avatar
Shaun, my advice for you is, get some good adj. shocks, i have wheel hop too & been kicking myself over it, i'm sure my issue is shock related, those HD ones your useing aren't really intended for drag raceing, also, that eddy TA is on the flimsy side (i had one), but replaced it with a BMR.
Old Aug 27, 2008 | 01:18 PM
96lt1m6's Avatar
are your LCAs paralell to the ground? they should be.
you have an adjustable TQ arm,i would use -2 up to -3 degrees see if that stops the hop..
by chance is your car lowered at all,if so your axle could be shifted off center and that could also be
giving you a hard time.then you would really need an adj. panhard to center the rear....
Old Aug 27, 2008 | 01:56 PM
ty_ty13's Avatar
7 Second Club
need more wheel speed...
