Drag Racing Tech
need to archive this for others to use: battery relocation
Old Sep 3, 2003 | 07:01 PM
java's Avatar
From: no stops signs, no speed limits .... on a highway to hell
Default need to archive this for others to use: battery relocation
battery relocation
Old Sep 3, 2003 | 07:06 PM
felton316's Avatar
Default Re: need to archive this for others to use: battery relocation
Damn good article!!
Old Sep 3, 2003 | 11:22 PM
Colonel's Avatar
Nice.
Old Sep 4, 2003 | 12:32 AM
soldier6552's Avatar
Does this mean I can do this myself?
Old Sep 4, 2003 | 05:53 AM
mikey's Avatar
LS1TECH Sponsor
Call be butt head...
Old Sep 4, 2003 | 08:17 AM
java's Avatar
call be butthead?
hey, anyone have pictures of their connection method for an LS1?
I am thinking of a using distribution box for car stereos and just cutting the two positive wires running to the battery now .... splicing them together and running to the distribution box. Then running the new cable to this box. Route the old ground cable to a location on the frame (Alan Futral suggested the sway bar bracket).
This should work huh?
Old Sep 4, 2003 | 10:36 AM
LS1x2's Avatar
Formerly 4mulaJoe
Did one of you mods delete my post?
I pointed out last night that the pics are of an LT1 car and it's easier to run the wire on the other side of the car on an LS1 car.
Old Sep 4, 2003 | 11:44 AM
Colonel's Avatar
Not that I know of, Joe. Why would we?
Why would it be easier to run it down the driver's side. I ran mine down the passenger's side.
Old Sep 4, 2003 | 12:29 PM
LS1x2's Avatar
Formerly 4mulaJoe
Okay. I just remembered posting it. Come to think of it the site was unavailable with those database errors for a few minutes after that happenned..hmm.
Anyway, on an ls1 car you don't have that positive battery terminal on the passenger side like that. It is on the driver's side by the fuse box.
What I did was run a cable from the positive post by the fuse panel back to the trunk where I put a battery box. I ran the ground from the battery to the frame. I ran new #4 cables I made myself to the starter and alternator. IT was pretty damn simple once I found all the parts. I used #1 welding cable for the main wires.
Old Sep 4, 2003 | 01:34 PM
991LE's Avatar
Do you have to have an external cutoff switch if you relocate your battery?
Old Sep 5, 2003 | 08:48 AM
java's Avatar
yes ... if you want to be NHRA legal
Old Sep 6, 2003 | 02:33 PM
java's Avatar
Still have a ground issues somewhere, it was there before I relocated the battery. The PCM resets back to 0 miles each time and the guages go up and down after cranking. ANyone know of a common ground wire or spot missed when reinstalling the engione or making a relocation? I have looked everywhere and can't find anything unhooked. I did leave the stock battery ground hooked to the stock place on the shock tower.
just finished the relocation ... couple of tips;
1.) bought a AudioPipe distribution box at the local car stereo store ($30) 1-#1 guage in and 4-#4 guage outs. Mounted where the stock battery used to be.
2.) The Taylor kit doesn't mount level in the back, I cut a piece of 2x4 to level it out
3.) Need at least 4 5/16 bolts minimum of 4 inches 4" long
Old Sep 10, 2003 | 11:08 AM
java's Avatar
From the NHRA Website ... notice the part about NHRA approved sealed battery box
I have a street car that I occasionally run at the strip. I've relocated the battery to the rear. What else do I need?
Any car with a relocated battery must be equipped with a master electrical cutoff, capable of stopping all electrical functions including ignition (must shut the engine off, as well as fuel pumps, etc.). The switch must be located on the rear of the vehicle, with the "off" position clearly marked. If the switch is of a "push / pull" type, then "push" must be the motion that shuts off the switch, and plastic or "keyed" typed switches are prohibited. Also, the battery must be completely sealed from the driver and/or driver compartment. This means a metal bulkhead must separate the trunk from the driver compartment, or the battery must be located in a sealed, metal box constructed of minimum .024 inch steel or .032 inch aluminum, or in an NHRA accepted plastic box. In cars with a conventional trunk, metal can simply be installed behind the rear seat and under the package tray to effectively seal the battery off from the driver. In a hatchback type vehicle the battery box is usually the easiest solution, since the alternative is to fabricate a bulkhead which seals to the hatch when closed. At present, Moroso is the only company which offers an NHRA accepted plastic battery box, part number 74050.
Old Sep 10, 2003 | 11:53 AM
JS's Avatar
JS
My marine battery box is accepted according to the NHRA?I dont have a cutouff though and they broke my ***** the last time I raced so now I dont drive in without the speaker grilles in place
Old Sep 10, 2003 | 01:05 PM
java's Avatar
the box mentioned above is the only plastic box that is NHRA approved
Old Jun 20, 2006 | 09:57 PM
damon_Z's Avatar
Thanks for the info.
Does anybody know if the Taylor battery relocation kit and/or the aluminum battery box already has the kill switch included? If not, then where can I buy a kill switch? Thanks in advance for the info.
Old Jun 30, 2006 | 07:17 PM
markp03's Avatar
tag for later
Old Jun 30, 2006 | 07:41 PM
NA$TY-TA's Avatar
Holy 3 yrs ago batman................................. Rules have changed in the last 3 yrs since this post was started.........................
