Drag Racing Tech
2800 vs 3600 stall upgrade
Old Sep 16, 2008 | 08:04 PM
silverz28camaro's Avatar
Default 2800 vs 3600 stall upgrade
well i am trading in my 2800 1.9 stall for a 3600 2.53 stall.
I have ran a 11.706 @ 117.22 with a 1.70 60'
mods are full bolt ons, 3.73 12 bolt. 3350 race weight, tubular suspension and 245/50-16 nitto 555r tires. tr224 cam and ls6 heads
assuming i get good traction what kind of gains may i see with the stall change?
I will be going to the track soon in a few weeks to get the results anyway but i just want something to shoot for.
My guess is a 11.49 @116 with a 1.60 60'
make a guess and if you get it right i will ups you a snickers bar.
Old Sep 17, 2008 | 07:12 AM
BlackScreaminMachine's Avatar
Internet Mechanic
From my experience, that stall should pick up well. LS1's power band is shifted forward on a graph. I guess the big issue is what brand stall. Some are better then others.
Old Sep 17, 2008 | 08:42 AM
mike#9's Avatar
Provided it is a good stall....I would think you would gain .02 in et.......and around 1 mph.
Just a ballpark figure, but I think it is possible!
Old Sep 17, 2008 | 03:13 PM
358chevycamaro's Avatar
My guess is more than 2 hundredths! lol
If you don't light those Nittos up I am going to guess a little over a tenth. I would throw a set of ET Drags on there to help maximize your gain especially with that 60'.
Old Sep 17, 2008 | 10:54 PM
mike#9's Avatar
I did not even notice that I put that.....I meant .2 on the et. Thanks for catching my flub!! LOL
Old Sep 17, 2008 | 11:05 PM
waterbug1999's Avatar
I say you are going to break'em loose every time.. That 3600, 2.5 STR is going to hit harder then those little 245's can handle.
Old Sep 18, 2008 | 12:02 AM
I knew what you meant... lol
Old Sep 18, 2008 | 12:03 AM
Agreed 100%!
That's why I suggested the ET Drags...
Old Sep 18, 2008 | 12:56 AM
If you were going to run a MT DR, you might have a chance. But a nitto, nope.
Old Sep 18, 2008 | 11:24 PM
Thats exactly what a guy in an 04 cobra told me. He had the mickeys and i had the nittos.
My. 11.8 @117 1.70 60'
His 12.20 @119 2.00 60'
I recommended nittos to him after wards .LOL.
I know the mickeys will to better on my car but i still have the nittos and plan on burning them up before the mickeys are purchased.
I just got the 3600 in tonight BTW and the nittos aren't doing to bad. Hopefully i will have some new times in a few weeks with the nittos being pushed to their limit.
My best 60' on the 245nittos were 1.67. Ill be lucky to pull a 1.60-1.65
Old Sep 18, 2008 | 11:38 PM
tkimrey's Avatar
You should drop a tenth or two, depending on if you hook...
Old Sep 18, 2008 | 11:53 PM
What was your mph and what stall did you have on your 11.66 run?
Old Sep 18, 2008 | 11:55 PM
I'll be sure to post my times and slip when i get the chance to run the setup. Hopefully i can get the 11 second club under my name
Old Sep 19, 2008 | 12:07 AM
96lt1m6's Avatar
Nitto 245/50/16 DRs(20psi)
perf.transmission 2004r w/brake
vig 3600
lca,s,adj.panhard
1.46 60'
Old Sep 19, 2008 | 01:23 PM
drag shocks
Old Sep 19, 2008 | 01:24 PM
what is the other car in the next lane?
Old Sep 24, 2008 | 04:41 PM
Gaunt's Avatar
Losing
Old Sep 24, 2008 | 05:33 PM
vig 3600
lca,s,adj.panhard
1.46 60'
Nice... Still hard to believe its a nitto, and a 245 at that. I guess you had the right recipe to make it stick. What did you end up running??
Old Sep 24, 2008 | 05:36 PM
I have been running the same stall for years. Belive it or not its a 4000 stall from Fuddle.. That 11.66 run was a month after I put together my H/C, I think it was 116mph.
Old Sep 24, 2008 | 08:21 PM
Here it goes.
Went to gateway last night and ran;
1.599 60'
7.36 1/8
92.36 mph
11.613 1/4
116.27
Still on the 245 nittos!!!!!!! the car went 11.6 the first 5 runs with 1.59-1.64 60' times
towards the end of the night it started spinnin to a 1.70 60' and 11.7
other then that it was consistant
